Radiator fan not coming on.
Bluejeep35
Last summer the fan stopped working. I have replaced the fan, the relay, low speed fuse, checked all other fuses, and still no luck. What else am I missing?
Your engine coolant temp sensor would be the other sensor that would stop working that would cause it not to come on or your thermostat is stuck open.
Did you check all your wiring before you started throwing parts at the issue?
