rsmwrangler
i'll be getting my 2.5" lift installed fairly soon, and as part of the install, i'll be throwing Synergy adj front TB and adj front LCA's.
I've never used a double adjuster feature like the ones in this bars, typically with the regular style LCA's i'll adjust the bar to desired length, and then gorilla tight the jam nut, in this ones it seems a lot easier to set as i figure the only thing that will be tighed up is just the pinch bolt correct ?
So i've found as a starting point to adjust the TB to 32 7/8 long eye to eye, and for the Front LCA's, to make them 23" long eye to eye
Question is, should i make them that long like this, for example, this would be 32 7/8 eye to eye
20150822_123610 by SilverFJ RSM, on Flickr
or like this? also 32 7/8 eye to eye
20150822_124005 by SilverFJ RSM, on Flickr
Also the track bar came with 2 metal bushing sleeves attached to the pinch bolt (I guess just packed like that),
20150822_121948 by SilverFJ RSM, on Flickr
Are those sleeves supposed to be installed like ?
20794089205_d4993c7e54_o by SilverFJ RSM, on Flickr
Another question, was i supposed to get some sort of tool with the Synergy track bar to turn the adjuster thing ? or a pipe wrench would suffice?
The LCA's feature a regular nut, but the track bar has that adjuster nut with little holes in it
and finally, my guess is that greasing zerk in the lcas will be facing up toward the chassis instead of facing the ground once the LCA is installed correct ?
2015-08-22_01-37-29 by SilverFJ RSM, on Flickr
Thanks a lot.
Thanks a lot.
