Pro rock 44 sway bar question
QuicksilverJK
Just finished up installing the PR44 and hit a hiccup. What is everyone running for sway bar manual disconnects? My pins are too close to the ram/ track bar mount so I won't be able to use my metalcloak ones.
I use metal cloak ones on my pr44 but I had to completely remove a tab to make them work.
I've run into the same issue with my g2. I just use a bolt on that side.
Sent from my SAMSUNG-SM-G935A using Tapatalk
In order to clear the pin I would need to take quite a bit of material off of the bracket. I ended up making a removable pin out of a 9/16 bolt cut to length and drilled for the retaining pin. Seems like it is gonna work out ok [emoji106]. thanks guys.
