Hey all you TJ and LJ guys and gals out there, here's a press release that I just got from Rugged Ridge and this one is meant for you. Check it out
RUGGED RIDGE INTRODUCES THREE NEW LIGHTING MOUNT OPTIONS FOR JEEP TJ/LJ WRANGLERS
New Mounting Locations for Perfect for Extra Illumination on the Trails
Suwanee, Ga. (April 5, 2016) – Rugged Ridge®, a leading manufacturer of high-quality Jeep accessories, today introduced three new lighting mount options for 1997-2006 TJ and LJ Jeep® Wranglers.
Designed to help Jeep owners easily add additional auxiliary LED lighting needed for nighttime trail rides, Rugged Ridge designed each new lighting mount options in a tough long lasting textured black finish.
• The Windshield LED Light Bar Mount is constructed from sturdy two-inch welded steel tubing and is secured to the vehicle using specially engineered A-pillar brackets that replace the factory windshield brackets. The contour hugging light bar frames the windshield, accommodating three Rugged Ridge 13.5-inch LED Light Bars with low profile tabs.
• The Hood Mount Light Bar supports up to five LED auxiliary lights. It mounts to the top of the Jeep’s hood using existing factory hardware and mounting points.
• The Dual A-Pillar Light Mount brackets are constructed from heavy duty steel and are easily mounted to the lower windshield mount using existing mounting bolt holes. No drilling or cutting required for installation.
”We wanted to take the same light mounting versatility that we have for the JKs, and bring them to older model Wranglers,” said Chris Kudika, a Design Engineer at Omix-ADA. “The result is a reliable, convenient and affordable way to mount your lights for off-roading.”
The lighting mounts are backed by Rugged Ridge’s 5-year limited warranty and are available for purchase through select Jeep and off-road parts/accessories retailers nationwide.
