jeeeep
Installed the Dometic wiring harness which includes a standard 12v plug and 12v screw in plug, it's now up and out of the available storage space which I didn't like about the stock plug.
What I do like about the stock plug is the fuse can be moved to become ignition switch powered which is what I use when traveling with a cooler.
I plug a portable power battery into the 12v plug which charges while driving then shuts off and the portable battery keeps the cooler going without it draining the starting battery.
Now that I've wired the Dometic direct to battery, I'd like to wire it to be ignition switched and can't decide if the easy way (piggyback fuse) would be as good as a relay switch.
The Dometic wiring has a 15a fuse, the stock 12v outlet uses a 20a fuse but I'm thinking even if I didn't use the stock 12v plug it would still be limited to the 160w max rating where if I use a relay I could safely plug in a 300w inverter to maximize the portable battery charge during shorter drive times.
