jeeeep
Benefit to being close to their shop, I got an email last week that the new mounting system was here, so a quick order and I was able to pick it up and get it installed today.
Those of you wanting to install, if you haven't installed your sport cage yet, get the trail rocker installed 1st. If you already have it installed, I recommend removing the driver side support to make it easier to run the wiring.
Spent a long time trying to fish it through behind the dash but ended up running it behind then down the side where the RockHard support won't pinch it. I'm now thinking it may have been faster to remove the support.
I like how it looks - also got the winch rocker switch controller :thumb:
here are some photos, I'm not very good at taking photos during the process only because it slows things down a lot so my hats off to all those of you that photograph the steps on your installs :thumb:
I went with the 6 rocker panel, an 8 rocker panel will fit too.
the ARB switch is actually for my ARB fridge but I just realized it lights up and I need to switch that rocker to a non-lighting rocker because when I'm using the fridge I will leave it plugged in overnight and dont' want any extra power draw.
wiring is slick as hell, plenty of wire in the harness, i'll need to add more items since I have the room
Thanks again to Painless for dealing with me, glad I waited for the new mount to be made available and I didn't have to modify my PSC reservoir location :rock:
