303jkpatriot
I picked up the Painless Performance Trail Rocker for my '15 JKUR Auto and wanted to post a few pics of the install and final product as there were not a ton on here when I was researching it. I realized shortly after opening the box the reason I couldn't find any write ups on the install was because they did a pretty outstanding job on the Installation instructions. Below is what all is included in the box and an idea what to expect from the installation manual:
They do good job of including everything needed for the installation process including plenty of zip ties, fuses, and enough lead wire to reach the back of a JKU. The Trail Rocker fuse box mounts using the plastic battery tray but still leaves adequate room for pulling the engine cover off and checking the oil :
For me the trickiest part was getting the wiring harness from the Fuse panel through the Firewall of the jeep :
I ended up cutting the rubber plug in half to get the harness inside and then pushed it in tight with a little silicon after. I wasn't joking about the amount of wiring included but I would rather have too much then end up splicing a supply wire:
The end result :
For those with an auto this was a pretty seamless install and good option if you don't use the mesh pocket on your dash for anything more than junk. I currently have it running reverse lights, Pillar Spots, and Rigid 10" bar on my bumper with the no problems.
The end result :
