P0128 - Thermostat Rationality error 2012 JKU
Amrth
Hi All - A couple of weeks ago the check engine light came up, while I was on the highway.. Quick glance to the engine temp, showed it had not reached its optimal temperature. Reached back home and took a look in the diagnostics, I was able to get the P0128 - Thermostat Rationality error code. Looked up online and the results stated showed it might be a faulty thermostat or any leak in the coolant line.. I went ahead and cleared the DTC's and for a couple of weeks I let the engine heat up before I take off and I've observed it takes at-least ~10-15 mins on idle for the temp to reach at mid level. Again the light popped back up last night and I want to get this rectified.
I'm strongly planning on changing the thermostat, because I'vent found any leaks in coolant and a search on how to do it brings me to WAYLIFE thread, which make me more happier than ever. Thanks to @scull20 for this write up, so before I land up with this job, is there anything else that I should be looking at to rule out other possible causes?
also how soon should i get this fixed, I mean now I really wait till the engine temp gets to mid to start my drive, so I'm assuming at least this work around will not have an adverse affect on the engine right?
http://wayalife.com/showthread.php?35551-3-6L-V6-Thermostat-Housing-Replacement
Cheers,
It sounds like your tstat is stuck open which won't hurt your engine, but will take your heater longer to start working. If you get a laser thermometer gun, you can shine it on each side of the tstat and see if it's stuck open or closed.
Based on the motor not getting to temp I'm gonna say it's a stuck open thermostat and allowing the engine to "over cool"
Thanks WJCO.. I might have to check with the members of local club if they have one that I could use or look at renting it from a auto-store if they have it. In both the cases a replacement is inevitable, am I correct?
You don't need a gun to test the heat, just use your hand. The upper house should be considerably hotter than the lower hose. If they feel about the same temp it's stuck open. If the upper hose is colder than it's stuck closed
They're 25 bucks at a hardware store and a general good tool to have. If the tstat is stuck open, it's not going to hurt your motor, HOWEVER, your fuel injection system is designed to run based on the ECT input, so it could affect mpg and engine performance if the PCM isn't getting an ideal reading from the ECT sensor. If tstat is stuck closed, you would have already noticed major overheating concerns, it happens quick. Also for me, I replace the tstat on all my vehicles around 30k to 50k just as a preventative measure. For such a cheap part, it's worth it to me to not have it stick randomly.
Did this test earlier and that's one of my reasons to go for a replacement. Thank you.
Sound like my plan of replacement is finalized, really appreciate your responses and time to order a OEM part and get on with it.
Cheers'
