Eugene the Jeep
So I have tried all the usual fender products from tire foam to back to black and wipe new. The tire foams and back to black worked well for a while but recently they weren't working well on the white streaks on the fenders. I did try wipe new as well which did work well on the black parts of the fender but turned the white streaks to gray. I did try a couple of coats of the wipe new and it still didn't work.
I found on an other forum that KIWI black leather dye on the fenders. I already had some in the garage so I tried it and it worked really well. My fenders and back to black and look like new.
Got it from Walmart for about $4.00
Fender before leather dye
Front fender half dye
If you do try to use the dye on your fender I found that its best to work the dye in parallel to the body of the jeep in straight lines and keep the applicator wet. The applicator has a tendency to leave a little bit of foam on the fender as you are applying the dye. make sure that you use the applicator to remove the foam from the fender before it dry's. If you apply to much dye you can use a cotton towel or old t shirt to remove the excess dye before it dry's, it will leave streaks if you put to much dye on the fenders.
I applied two or three coats on each fender until the coverage looked right.
I'm hoping that the dye will last longer then the other products that I have been using. It definitely made difference on my fenders.
I will post more pic's in a month and see what they look like.
