Anybody know what causes this and/or how to fix it. Jeep is a JKUR w/ stock bfg mud terrains.
View attachment 168449View attachment 168450
I believe balancing and worn ball joints contribute to this. My fronts are looking the same.
Granted everything seemed tight on mine. How many miles on your rig Frank? Might have to really look at mine.
25k about 23k of those on 37's. Replaced a unit bearing and have crown HD BJs sitting in the garage waiting to be installed.
Keep hearing the crowns are the best to use.
"Best" is a bit of a stretch. A better buy for sure being that they're the same joint as Synergy and Alloy only cost lest. Dynatrac ProSteers are the "best" but they do have a price tag to match.
My stock tires did the same thing. Combination of poor balancing, lack of rotations and air pressure is the cause.
Frank might be correct about the ball joints. But I now have 37s, with the same ballpoints and not nearly the issues. I've been pretty regiment about getting them rotated and balanced between 4-5k and checking air more often than that.
Edit: BTW, it's called cupping and you can search causes as see the most common to other causes.
