New to jeeps have a question?
Cyberguy79
Hi my name is Paul and I have a 2011 jeep Rubicon with a 2.5 inch lift ( here's the link) http://www.ebay.com/itm/Rough-Count...ash=item544048cba8:g:JZkAAOSwKytZE5jw&vxp=mtr
I know its not anything spectacular but i wanted a little bit of lift and not knowing anything about lifts this was a good starter one as reading the reviews and such.
So I have a question.... while driving down the road or e-way it kinda feels like swaying or body rocking ( never had a jeep remember so the terms are kinda weird lol)
everything in the front has been checked out but the shocks (they were new about 8 months ago) should I upgrade the shocks to a 2.5" lift shock and change out the springs to 2.5" ?
My wife says its kinda scary to drive any help or ideas would be greatly appreciated thanks
ok I will check it out but not really mechanically inclined lol. Thanks for the info
To check your caster you really don't have to be mechanically inclined. With a $10 magnetic angle finder from HD/Lowes/HF and that instructional thread you can at least rule out the caster issue without getting ripped off by an alignment shop telling you differently.
Or use an app on your phone for free
I had an issue like this after my RC lift. I installed Rancho geometry correction brackets and it solved my issue. After I lifted my jeep my caster was in the low 3s. With the brackets you lose a little clearance but you gain on road stability. If you are not a hard core jeeper the caster cam bolts could be a cheaper solution.
Sent from my LG-H811 using WAYALIFE mobile app
I have the 2.5 RC lift and the dealer installed the cam bolts when I took it in for alignment.......:grayno: I wish they hadn't. You would be better off buying adjustable lower control arms. If I'm wrong I am sure i will be corrected. Everything I have been reading on here says..cam bolts isn't the way to go.
Also check your tire pressure. Low pressure will give the sway effect.
That's why I went with the geometry corection brackets by Rancho. They are less than control arms and have multiple upper control arm positions to correct the caster. I am on the 3.5 inch RC lift. I didn't go with cam bolts as they don't have that much adjustment and can be knocked out position while wheeling.
