new springs=front end alingment?
jeffd
If I go with new rubi springs ie 19 vs my current 17 springs will I have to have a front end alignment done? how about if I were to go with a aev lever kit or a similar 1" to 2" kit? My goal is to just level the front end not to go with bigger tires. I am happy with my 245/75-16's on my 2013 sport jku for the time being. thanks jeff
kaptkrappy
Nope, just swap it and go
what he said. it's not needed and without adjustable components, the only thing an alignment shop could do is take your money.
These guys are pretty smart and correct.
I just recently did the factory spring upgrade and 3/4" leveling spacer in the front and my alignment didn't change.
Factory Spring Swap
I checked the toe in/out before and after using the write up on PROJECT-JK
Basic Do-it-Yourself Jeep JK Wrangler Front End Alignment
My steering wheel did not need re-centering either, so you should also be good after leveing out your JK.
