NEW PRODUCT: Rock Hard 4x4 DoubleWall Crossmember for Jeep JK 07-11 3.8L [RH-9060]
http://www.rockhard4x4.com/product_p/rh-9060.htm
Upgrade your factory 14-gauge stamped steel transmission crossmember to our 3/16" + 3/16" MASSIVE 3/8" DoubleWall Crossmember!
Total Weight: 27 lbs.
Our top and bottom plate 3/16" thick design gives you a total of 3/8" plate steel strength! Designed to fit 2007-2011 3.8L engines.
Ease of Install
In under 1 hour - including removal of your factory crossmember - you can complete this critical upgrade. We designed this crossmember to be a drop in replacement for your factory transmission crossmember. Simple hand tools required - no drill cutting or welding!
Precision Made Strength
Each crossmember is laser cut from 3/16" thick steel and coated in our weather and debris resistant powder coat finish. Strength is proven on virtually all Jeep enthusiast forums with glowing reviews. Since 2007 our skid plate system has been the undisputed leader in undercarriage protection.
Ease of Install
