So they said that they overfilled the fluid and decided to take some out? If so, I would drive around normally for half a day and keep an eye on the transmission.
Nope I'm going tomorrow again and demand to get it fix properly if
Not my bros lawyer will contact them for scamcause is leaking in the same place
still leaking?
can't tell which shop you took it back to for the ongoing leak, the transmission shop or the shop that removed and installed it...
what did they do, just remove some fluid?
check your transmission dip stick and make sure it's at the proper level - you don't want to burn the transmission up because not enough fluid.
The shop that remove the trans and make the deal with the other shop and yup the level is good but leaks a lil I'm super angry
Brankz...this should make u happy ...
what does the transmission shop say about the leak?
