bo9roadking
Finally got my Evolever and DoubleThrowdown installed. I need to do a few tweaks to the Evolever mounts on the rear axle because I installed everything with my Rock Krawler X Factor Long Arm control arms instead buying new Evo control arms.
Since the rear axle is moved back an inch with the RK control arms, I may make some new brackets to put the Evolever mounts more to the front of the axle instead of trying to work with them on top of my axle where they compete for space with my truss/bridge that supports my upper control arm. Instead of the EvoLever heims being straight up and down between the axle mounting location and at the pivot point, they are at a slight angle pointing towards the rear of my Jeep. The axle is slightly behind the pivot arm that the coilovers and bypasses connect too, so I need to move the axle mounting point forward an inch to get the heims to be perpendicular.
Here are a couple of pics while my JK was on a rack at the exhaust shop to get the rear exhaust rerouted.
