atrollip
Hi all
Looking for a bit of help. I have been trying to make the wiring work but struggling a bit.
I used Maxxima wiring harness from EVO tail lights cut both adapters off, with Maxxima Tail lights.
Currently they way it's wired it works, the only challenge is if I brake and turn only the brake shows.
Also the colours on the jk wiring are slightly different.
On jk side:
Black - wired to white of resistor harness (female adapter side) and to tail light top right white
White/ orange (left side) which is purple and white on right side - wired to black of resistor and black of tail light.
White with grey ???? - wired to led top left red (supposedly reverse)
Green with white / suppose to yellow white -
White with green - these are connected together to red female side resistor and to red to red stop turn on led.
If I split the green with white and white with green the indicator hyper flashes.
Any help will be supper appreciated. I even tried wiring in a marker light for turn indicator also so that if i brake and indicate the marker will still flash but as said when i split the 2 white green and green white the resistor doesn't work.
Sent from my SM-N9005 using WAYALIFE mobile app
On jk side:
