Lower front control arm install question
blazer
Replacing front lower Teraflex control arms with adjustable Rock Jocks. (they were in stock and I went to pick them up) Teraflex have worked for 10 years but inside threads rusted out. They were installed with the curve or bow curved outward, but Currie says to have the curve of the arms curve inward towards the diff. So....does it make much of a difference? Currie did say it does not make much difference but bowing inward would prevent the tire from rubbing at flex. Makes sense. So.....what would be the best way. Thanks
CalSgt
If you have to replace them might as well put them on the way Currie says... I think my EVO ones on the JL were bow in
blazer
Talked to EVO. Said theirs's are straight, no bow, said probably does not make much of a difference installed either way.
blazer
Found the answer Dec. 22 2007, Eddie's write-up, ...."and the bend in the arm pointing inward"....
