Lighting Help
Theschist
Has anyone experienced a bad contact in their turnsignal/headlight switch on the steering console? I cannot dim the interior lights and it will flicker between full dim and full bright depending on how I push the stick. I think it is a bad contact within the signal lever, but before I pursue that, I wanted to see if anyone else has experienced the same phenomenon. I have done some custom wiring, but I can't see it causing such an intermittent condition. FYI, I have the 2012 JKU Manual.
It could just be dust or corrosion on the contacts. Cycle it up and down a few times to brush the junk off.
Same thing happens to the Neutral Safety Switch on my XJ, sometimes it wont start cause it doesn't think its in park. Cycle the shifter up and down a few times, and the "wiper" literally wipes the corrosion away.
Welcome to WAL. Stop by and introduce yourself in the "Give Us a Wave" section!
