Hey jeepers - new here and loving all the inspiration. Here's to hoping I can help someone out - I really wanted some lighted vents from AMoffroad but didnt want to spend the $400. I decided to go it on my own - some Amazon packages later and here is the results - I am putting them in the Jeep tomorrow. Until then here are some build photos.
I can add links to LEDs and connectors if anyone is interested.
Step 1 - remove vents - There are videos on youtube to help.
Step 2 - I had to sand the internal sides of the vent so the LEDs and connector would stick. I used a Ryobi rotary tool.
Step 3 - Get you some LEDs - Amazon.com: EverBright Red Led Strip Lights, 5M /16.4Ft 600SMD Waterproof IP68 Flexible Led Light Strip for Undercar Lighting Kits House Bedroom Kitchen TV Party Light Decoration with 5A Power Adapter : Home & Kitchen and connectors - LightingWill 10pcs/Pack Strip Wire Solderless Snap Down 2Conductor LED Strip Connector for 10mm Wide 5050 5630 Single Color Flex LED Strips - - Amazon.com
Step 4 - trim LEDs into 9 Lights and install the connector so RED wire goes to positive.
Step 5 - Glue onto inside of vent
Step 6 - Install in car and wire up to your switch box or add a toggle switch with relay.
