Lift conversion question
MSJKU11
Replacing my RC 3.5 lift and was wondering something. I'm slowing changing out parts to the evo enforcer stage 1. The RC came with a dropped pitman arm which I'm replacing with a stock arm and drag link flip. The RC kit also came with a front and rear trackbar bracket. Should I replace the rear with evo or leave it be until it needs replacing due to wear or is there some better geometry going on with the evo one? On the front, should I just ditch it? Thanks in advance guys
On the front if you flip the drag link you will want to raise the track bar too. If not you will get bump steer. You will want 3” of bump stop too
Evo's drag link flip comes with the bracket I see. So that will just be replaced then. I do have 3 in bumpstops already on from the previous kit.
