KC Lights not working?
aaronstephen
I just bought some KC lights to be mounted on the A pillars. Followed the diagram and checked multiple times for errors. Wired the switch exactly as the instructions say and the green led light comes on. When I flip the switch the relay clicks as it should. But no light. Any suggestions? I'm confused. I've checked the fuses and they look good as well. I know the ground for the switch is good because the green light comes on. I've even tried placing the ground wire on the negative terminal to make sure the ground wasn't the issue.
How about the ground on the relay? Is the relay wired correctly? I had a similar issue with my Hellas and I had the relay wired backwards, luckily it didn't kill it but was a stupid mistake on my part.
I just found the problem. Schematics were wrong. Hot wire from relay needed to go to positive and the instructions had it going to ground.
