New! Received as a gift and never had the chance to use before I sold my Jeep. Free Shipping to lower 48 states
"Save time and ease the task of airing down with a set of JT Brooks Automatic Tire Deflators. Once calibrated, the JT Brooks Tire Deflators automatically air down to the desired pre-set PSI without having to monitor the pressure. The deflators automatically shut off when the preset PSI is reached. Deflators can be recalibrated to any PSI from 6-32 PSI. and calibrating is simple with the included instruction card. Saves time and frustration by eliminating the need to manually deflate your tires. Nickel plated brass provides superior durability. Stainless steel precision spring delivers unrivaled accuracy. Once Set, they are ready to use again and again. The deceptively simple two piece design is easily disassembled for cleaning. If you frequently air down to different tire pressures and want to eliminate the calibration process, then the Pro Set is exactly what you need. Each Pro Deflator has a precision laser engraved scale to dial in your desired PSI. Each set includes 4 deflators, a ballistic nylon storage pouch and a durable plastic instruction card.
Made in the USA."
Made in the USA."
