bthomas
Tried to find info on this here and came up short, so I will post this for the next guy that might want to do this with out having to refer elsewhere. I found a fair deal on a set of take off Rubi Rails local to me but they were off of a 4 door, so I proceeded to do a little homework & confirmed my suspicion that they are the same at the front & middle mounting points. The JKUR models are just longer with a third mounting point towards the rear of the Jeep. So, after bringing them home, I grabbed my phone for pic's, a few tools, my trusty Sawzall, files, some tape, news paper, & flat black paint to seal the bare edges. I did have to make a run to my local True Value for 4 metric J clip body nuts, they had them for under a buck each. Here goes the pic-u-mentary. Hope someone gets some use of it.
Stock Ruicon Unlimited Rails ready for surgery.
Pulled a wheel of to get a good measurement, Note jack stand under frame...Safety first, right? I cut mine the same lenght as the pinch seam for now, I will be going to 35's at some point in the future & I will re-cut & trim pinch seam to clear when the time comes.
Got my length set & marked with masking tape to make a straight cut. I cut 20.5" off the back side of the rails to come flush with stock pinch seam. My Sawzall still had some mesquite bark & dirt in it from the last camping trip...:blush:
Finished cut on first rail.
A bit of measuring & guesstimating to drill a new hole for the plastic Christmas Tree push pin retainer.
One of the rails was almost ready for the retainer, all I had to do was drill a hole in the oval clearance area.
Filed off rough edges inside & out, then hit it with some flat black Krylon to seal raw metal.
Got a little excited & cut a bit crooked on the second rail, so the cap did not sit square & flush, there is about 3/16" of a gap. So I ran tape on along both edges.
Then filled the gap with black RTV silicone.
I peeled the tape off right after smoothing out the still wet silicone & Viola! No more gap....Until you squint! (a little blury on this one, sorry.)
Checked for clearance the best I could with a floor jack. It'll be fine, till I go to 35's!
Finished install.
SALE!!! Today only!!! Rubicon Sliders 75% Off!!!
Well, I hope someone gets some use of this. I'm sure these will be replaced in the future with something more stout, but for where I'm at with my wheelin' & the minimal investment in time & materials, they will do fine for now. It was a real easy job to do. Took only a few hours with breaks to enjoy a frosty beverage or four :beer: on a 108* Arizona summer day! Whats better than modding parts to mod your Jeep right?
Billy
Finished install.
Billy
