Jku drive shaft
In need of a stock front driveshaft it's an 08 jku no money to upgrade yet and mine started leaking grease... Thanks in advance!
If you don't plan on wheeling anytime soon you can just pull the front shaft off till you get a replacement. Your just obviously going to lose 4wd
Yeah that would suck but might be only option. I might replace the rzeppa but I hear you can't replace the u joint
You can prob find a used oem shaft for way cheaper than it is to replace the rzeppa and the boot. Just search craigslist in your local area and I'm sure a member here might be able to hook you up.
