LōD Offroad
WILL NOT WORK WITH JL 4XE JEEP!!
Jeep JK / JL Destroyer 4 Door Sliding Roof Rack option is available to be added on the the Base Roof Rack for the Jeep JK and JL at any time to customize your rack the way you want it! This Sliding Rack option allows you to have full access to the Soft Top for easy up and down operation. Yes, the Destroyer Sliding Rack option will both work with the Sky One-Touch Power Top, the Soft Top in Sunrider position, and Hard Top. This is one of the best features of the LoD Destroyer Roof Rack, no need to unload your gear just to open your top on those hot summer days!
The Sliding Rack option also comes with 6 Crossmember Bars as standard equipment.
The Sliding Rack driving load capacity is 300 lbs
The Sliding Rack static load capacity is 800 lbs
Please Note: Sliding Rack requires the Base Rack to work, This is a bolt on option that can be added to the Base Rack at any time!
View the product here:
https://lodoffroad.com/products/jee...sliding-roof-rack-option-mounts-to-base-rack-
MUST CALL to receive the 10% OFF forum discount.
765-385-0631
Add-on items
Optional items:
Base Rack Crossmember Bar Kit (works with Base Rack Only, does NOT work with Sliding Rack option)
Sliding Rack Kit (comes with 6 Crossmember Bars)
Aluminum Floor Kit ( 2 panels per kit, Roof Rack can hold up to 6 panels, works with Base Rack cross bars and Sliding Rack cross bars)
Drivers / Passenger Ladders
Light Mounts
Axe / Shovel Trail Tool Mounts
Hi-lift Jack Mounts
Jerry Can Mounts
Rotopax Mounts
Universal Mounts
Accessory Tie Down
FAQ:
JK & JL Roof Rack
If you are only purchasing the Base Rack you will need the Crossmember kit to complete install and make the install complete for the base rack.
Base rack is required for sliding rack.
Sliding rack comes with its own set of crossmembers included. They are different than the base rack crossmembers. These crossmember bars only work with their assigned roof rack.
Sliding rack can be set up at the time of install to slide out either side, but can only slide 1 way when install is complete.
The rack that slides out the back of the Jeep was discontinued several years ago. We only offer the one that slides out the side.
LOD Offroad
