72dozer
I'll try to start this lil thread
ok this is what I used
1--- 14 gauge flat steel 26.5x13.5
2--- pieces or 1.25x3/16 flat bar 9 inches long
4---3/4 .120 wall tubing 1.5 long
Drilled 3 holes on each side to mount it to the wall which at the end of it should be 16 inch apart since most walls are built on 16 inch center
After that I layer it out where the. Bends would need to go and then flip it over and mark the other side
And the after u get it broke I'll
Have to check to see what degree I bent them to the way I measured was 32degrees
Next you weld the tubing to the flat bar
Then weld them
To the main piece from I measured 12.25 top to top of the tubing
Then weld them
