10frank9
Web Wheeler
Greetings all!
After a recent wheeling trip I found the need to upgrade my stock diff covers. I wanted to share what I experienced and let you all make an informed decision.
Note: I should've chosen better lines and I DID previously clearance the "lip" off the bottom of my diff covers.
This is the rear diff cover. You can see that it still peeled back a bit and the bottom of two bolts are damaged pretty good:
The front diff also has some damage to the bolts which will require a stripped bolt head tool to remove. The dent is from kissing a large boulder with the center of the diff (just to check rigidity if course).
Needless to say, I will be purchasing aftermarket an aftermarket diff cover WITH recessed bolts.
Hope this helps...... Be safe out there Wayalifers! Oh and choose your lines wisely :cheesy:
