Finn Sizzle
I am changing out my calipers and I was looking up what the torque setting are for the banjo bolt and for the clipper back to the knuckle. I found this:
http://project-jk.com/jeep-jk-write-ups/jeep-jk-wrangler-torque-settings#brakes
My question is on the brake caliper itself, there are 2 listed
Caliper adapter
Caliper adapter mounting bolts
Which is what? I would have thought the "mounting bolts" are what is bolted to the knuckle/axle, however it can't be set that low. So I'm looking for a brain check please.
Are the bolts that connect to the knuckle/axle just called the "caliper adapter" and the 2 bolts that are the housing for the brake pads called the "caliper adapter mounting bolts"?
Caliper adapter
