Anyone have any recommendations? My brother wants to mount my stock Rubicon tires. Looks like he needs a 2" lift minimum. Thinking of telling him to do a BB with longer Rancho 5000s. Should cost less than $400 for that.
I'd def look into the Old Man Emu 3" HD lift. It is one of the best lift's for the XK/WK for the money! It will give you a LOT better ride over a BB/spacer lift, and will easily clear 32-33" tires. It comes with all new HD springs, and new struts/shocks. If you want a bit more adjustability, you could go with just the HD OME coils and Bilstein 5100 adjustable struts and shocks. Just make sure you don't go over 23" hub to fender measurements up front, that's when you could have some front end problems. You can find the lift for around 700-750 from online vendors. Contact Kolak (kolak@aol.com). I have the lift, and it has been great on and offroad for the past 2 years! :thumb:
Thanks! Any pictures?
I personally drive a WK. So my pics would do your friend no good.....I did borrow a few pics from a fellow member off another forum for ya. Hopefully he won't mind me showing off his ride lol. He runs the OME HD on his XK with 265/70 tires. You will need at least a 1/4" spacer up front to clear the front brake calipers for your JK Moabs. The reason for this is because the WK/XK uses a larger caliper than you JK guys. Most guys with a WK/XK run a 1-1.5". I personally use spidertraxx 1.5" spacers on my own jeep and have had zero issues with them. They are very popular brand on my side of the fence, and have an awesome reputation and good customer support. Just make sure the spacer you buy is wheel/hub centric and your friend should have no issues. Also, due to the spacers you may need to do some trimming on the front pinch weld. It's a simple enough mod by cutting some slits into it with a cut off wheel and hammering it down as flat as possible. Then paint over the seam with some undercoating/bed liner to prevent rust. For the wheel well liners, cut a slit vertically up along the pinch weld seam. After that, heat the liner up with a heat gun and press one side over the other to have it overlap the seam. If you take your time, the liner should look almost factory when done. This will give you about an inch or more extra clearance inside the wheel wells. There are also some really good right ups if you google search "XK pinch weld mod". I had to do this all on my WK so I am speaking from experience lol
Now, onto the pics I promised!
P.S. If you're friend is looking for some armor as well, tell him to look at Steel Armadillo or 4xguard. They make some awesome stuff for our platforms!
Anyone know who makes this bumper for the commanders??
Sent from the"Zone of Influence"
Sorry, can't help. I thought this bumper is pretty cool. Don't know who makes it either. View attachment 67152
That was the old GetLost4x4 bumper! They had a limited run for that bumper back in 2009. There have been a few come up for sale every now and again. Only company I know making bumpers front and rear for the Commander is Steel Armadillo. You could try contacting Stone Soup as well, they were making copies of that bumper a few years back. Having a shop custom fab one up is always an option as well!
