Jam nuts
kevinp
Hello all,
I'm about to upgrade my rear suspension from a Rock Krawler 2.5" Max Travel set-up to the RK X Factor. Here's where I need advice. The jam nuts require 200 foot pounds of torque. Any tips on tightening a jam nut that tight without ruining the finish by using a vice?
Kevin
Sent from my Galaxy S5 using the Wayalife APP
Get a big crescent wrench or the correct size open end wrench, a breaker bar and some steroids and go to town.
Sometimes you have to get creative.
I tried this first but didn't work. Pine was too soft.
Then tried this. Broke my Hi-Lift jack(POS)
Then after selling a F-Body I had I came across some extra parts. One of those was lower control arm relocation brackets.
And started to run with that.
Then I tried to figure out how to lock down the brackets. I got 4 foot zinc rods that fit perfect in the holes.
Then I had to add some weight to stop the one side from lifting. So I added 120 pounds worth of bowling balls and another 25 pounds of tools.
I later figured out that putting a wheel and tire on the rods first then adding the 150+ pounds of bowling balls and tools allowed me to stand on the 24 inch crescent wrench with out any issues. This worked with all of the arms. I don't have a picture of the tire and bowling balls all on the rods but I think everyone gets what I did there.
I would tighten with a wrench as much as possible, then throw a cheater on and retighten. Then tack weld it.
I wouldnt worry about the finish on the nut just about rounding it off with a sloppy wrench.
Why do all control arms have jamb nuts? Neither end can rotate when bolted in. I'm sure there is a reason I'm just not sure
It's to take the pressure off the threads.
very slight play in the threads will eventually wear the threads out and strip them. Using a jam nut will help keep the threads pressed tightly against each other and remove that play.
ORE used to sell these jamb nuts that you tighten with a Allen wrench. I don't know if they still carry them.
I like the idea of using the extra brackets! I have tools to fit, it's just really hard to access some of them on the Jeep. I'll hit up Home Depot and see what I can come up with.
Kevin
Kevin
BTW you can almost throw out every starting measurement that RK put in the instructions. Do yourself a favor and pre-mount everything first before going through the troubles of torquing and red locktighting everything. The pinon angles weren't even close on my first try (2012 - 2 door) both front and back. :mad:
i put my lift on got everything set, jam nuts as well as i could then put it on the ground and torqued the axle/frame bolts to specs...then I put the axle back up on jack stands to give me some room to get a 24" crescent and cheater bar on the jam nuts to make sure they were tight...I also used some red Loctite on them before getting the final torque on them
