tastethebeast
Was changing my diff fluid and adding ARB covers and noticed a couple chunks missing. The teeth on the ring and pinion are perfect theres just damage on the front. What do you think?
UPDATE!
The dealer replaced my pinion, bearing, and seals under warranty. Apparently this is a fairly common problem with the pinion on 3.73 gears. However, the rear end tech said it is not necessary to replace if there are circular pieces missing on the top of the pinion where the serial numbers usually are. I would still inform the dealer just in case, but it should not affect the Jeep in any way. If there are chunk missing near or on the teeth, definitely have them take a look. The tech even admitted this would not be caused by lift, pinion angle, wheeling, etc so as long as you still have stock gears, you should be able to get this covered!
