Installing my lift tomorrow
rogerk93
I'm installing my Currie lift tomorrow and have a question. I've read up eddies topic on how to align the front end. But with the rear what should the measurements be with pinion angle?
I'm guessing u have a stock driveshaft. If so, the pinion should be inline with the driveshaft. If you have an aftermarket u-joint style drive shaft, the pinion should be the same angle as the output shaft on the transfer case (or close to it so as to not cause vibration).
