I bent my rear lower control arm on the passenger side on my 20k 12 2 door jk I could
Pilgrim55
Lower Rear contol arm bent
I bent my rear lower control arm on the passenger side on a 2012 2 door Rubicon, worried about rear end being out of alignment and tire wear. I have check out Rock Kwawler control arms that claim that you have more clearance not sure how much of a difference that would be. I have also look at replace all the rear control arms with adjustable control arm from Rock Kwawler. Or going the cheaper route and replace it with a stock control arm. Is Rock kwawler a good brand or what brand would you recommend. Any advice would be appreciated .
Id probably throw on a stocker for now to chill out your concerns and not rush into anything unless you have already done some research. Theres a lot of options and opinions out there.
if everything else is stock, I'd go with stock.
you can probably find some take-offs for cheap or free...
check out the recycler section
