dannymalkin
I am looking to buy a head unit to replace the stock one. I found a stock nav mygig sirius unit for sale used, but how much should I pay for it? Also would it plug right in? Thanks!
If you are wanting 430N(with Nav) I think they run from 800-1000 used and 1200 new at least in my area. If you are looking for just the 430(no Nav) they seem to run between 250-500.
As far as the plug and play, I'm not sure. Maybe someone will chime in that knows!
I bought my 430 with no nav for around $400. Easy install too. All there is to do on the install is take off the dash around the unit and there are 4 screws holding it in. And then pull the old out and slide the new one in. You do have to reconnect the plugs and cords in the back of the unit but that's not a problem. And then close everything up.
