Seahawkfan
Was crawling around under my Jeep tonight just checking things out. I noticed my Long Arm brackets don't seem to be ....... I'll let one you long arm guys tell me if this looks like yours do you see what I see?
This first set will the front lower frame side, both right and left.
To give perspective, Looking from rear to front. Frame rail on right and EVO CA bracket on left.
This is looking up front, lower, frame end, CA bracket.
Only welds I see are on those looks like scrap square tube. You can see the day light through the top.
I believe this is the top of front lower CA bracket frame end. Looks to be missing some welds
This the only other part of the front bracket I see welded.
Rear Lower frame end bracket top I think. Looks good I guess
Same bracket bottom drivers' side. No weld to frame. other side is welded along this rust line.
Any thoughts. Am I seeing this right? Did they get lazy? I'm not here to blast the shop that did the work, And I'm not going to name them. but I expected way more than what I got for this kind of money.
