Help me spend my money(lift kit)
777ekflyer
Hi all.
So after hrs of researching Ive come down to two lift kits. EVO enforcer 3 inch with either 2.0 fox adjustable shocks or the new BP-51 Shocks or the RK 2.5 Xfactor system with the same shocks. I have a heavy JKU 35 inch tires and for now don't do any rock crawling. All desert sand driving. Right now I have a procomp 2.5 inch lift with their es9000 shocks. A good starter lift, but want alittle more performance. I would like something that i can upgrade in the future. Another option would just to buy the evo 3 inch springs and adjustable lower arm or the jks control arm correction brackets and shocks. I already have front adjustable track bar, bump stops, brake relocaton brackets, rear track bar relocation bracket, and JKS flex connect sway bay link.
If you plan to go fast in the sand, I would go with the 3" enforcer with the evo spec king 2.5 shocks :thumb:
Much agreed. Sand dunes scream coilovers to me but i fully understand a budget on your build. 100% agree evo regardless. Bolt on Coilovers or enforcer
I'm trying to do my research and make sure I do this right the first time. I realize this is redundant for some of you. I've read a lot of coil over posts and went to the EvO site but still have questions. I want the EVO coil overs but I thought the Jeep must be lifted first so one has to have a lift first. Just want clarification that you don't have to buy a lift first THEN turn around and get the coil over kit. Again. The last Jeep just had a suspension lift and I was done. I have a JKU right now that has no lift now. Doing my research for my build.
Flyer, sorry for cutting in on your thread. That is a great looking Jeep. The windows are nice and dar.
The evo double d pro would have everything you need other than a front driveshaft. The bolt on kits would be missing the front lower control arms that you need. If you would get the kit north ridge sells, the enforcer pro stage 1 it has the d-link flip and lower arms you need.
I did a comparison. the Double D Pro comes with the bolt on long arm upgrade. Thank you. this clears up a lot and helped me. We're only one lift on this Jeep so it's got to be right.
I meant the enforcer pro, but yeah if you want to do a total lift upgrade and all long arms the double d pro is the way to go.
