Jersey_Devil
OK so I've been having a problem with my 2010 JKUR touch screen radio just simply not turning on at all when I turn the jeep on. Couple of guys had the same problem and said once they changed the battery it fixed it. Now today I auto started after work but when I came out it was off. I restarted it and within a minute it turned itself off. I figured it was something stupid and it would work later. Sometimes the auto start just wont work and the next time I try it works. So on my way home I try to beep at someone and my horn kinda works sorta, it was full sound but it cut in and out instead of just blasting. Then when I got home I tried the auto start, did the same thing, turned on but within a minute it turned itself off. So I sit inside and auto start it to see if any lights are coming on that would cause it not to work (ie: gas, check engine, temp) it turns on then within a minute it turned itself off and no lights turned on. I disconnected the battery and tried it again and it stayed on, I put the key in turned it waited a min and shut it off. Just for shits and giggles I auto started again..... Within a minute it turned itself off
now I do still have the original battery from 2010 still in it and everyone here knows I love my lights, so could my battery be causing this or should I take it to the stealership?
sent from my obama monitoring device
