Hard rock skids
gonow
Good evening all, after hitting my oil pan on a rock on my 2013 jku which I have since traded in for a 2017 recon I've decided to go with a hard rock oil pan trans and transfer case skid, question I have a 3.5 MK lift and they strongly suggested exhaust spacers as I am keeping my stock shafts for now will the spacer present any issues with the skids or will they clear?
Thank you for the help
JE
Sent from my SM-G955U using WAYALIFE mobile app
Get the front driveline
My 3.5 RE lift recommended replacing the front driveline, but offered the exhaust spacers. As you can see in the picture, after a little brush on a rock, my exhaust is now the lowest hanging part of the Jeep, and it's rattling against the cross member bracket. As you've probably read many times on this forum, do it once do it right. IMO the spacers push the exhaust down too far and you'll have issues with it rattling against any armour you have.
Without exhaust spacers I still have to use the rock hard spacer plate to clear the exhaust cross over. So I don't think it'll fit with the exhaust spacers. Pull them out and get a real driveshaft.
I agree. My spacers pushed the exhaust down to far and I had rattling on the cross member as well. Took them off. Going to get a new drive shaft. There was no way I was getting an oil pan skid on with the spacers
