I have a 19 gal aux tank in the Brute...it fits between the frame rails between and slightly aft of the rear wheels. It does add a ton of weight to your ass that is noticeable especially on hill climbs as the weight shifts rearward. However, I make sure it's near empty (or only 5 gals in it max) when I'm on the trail, so you don't notice it at all. When on road trips, it's nice to have 400 mile range, and cuts my fuel stops in half...and I can be selective where I fuel up (no worries about brand z gas
️ n the middle of nowhere cause that's the only gas for miles). My situation may be a bit different from yours since I have 139" wheelbase and a 5.7 which carries the weight better. If you can reliably keep only 25 gals in your tank when you hit the trail, you shouldn't notice any difference...but that's going to be tricky with only one fuel tank
