TrailHunter
This is specifically in regards to the T3X tent... but I'm sure this will work with the other models as well. The T3X when folded up is about 58" long... This makes it very hard to get it into the rear cargo area and impossible to put it on the back seat. I have been opening the back door, pulling the back seat forward, then sliding it in between the roll bar and the back seat.. just fitting between the hardtop.. Sort of a Pain in the Ass.
I thought, if I could just make it a bit shorter.... I did some experimenting.. and discovered you can make it shorter. Simply remove the Top Pole section from the tent before folding it up. It only adds about 1 min to your setup and take down time... But it makes folding it up a bit easier, tighter... and shortens the closed length from 58" to 54". That 4" gain allows me to keep it on the back seat or floor... and get it into the rear cargo area A LOT easier. Just throw the pole section into the bag and you are good to go.
If someone has a T4, I'm curious what the closed dimension would be.
T3X shown
T3X shown
