aaronstephen
when I get full droop in the front my front coil springs will drop at the top of the coil spring and no longer be under pressure. I have coil retainers on the bottom of the coil spring to keep it secure, but I was wondering if this is a problem? The coil spring will probably drop about an inch from where they are seated at the top of the spring (hope this makes sense).
also, my brake lines look fine but my tpms line is a bit tight at full droop. How do I fix that?
