ryan.ferguson1993
What's up guys. I purchased this 2013 JKU 10A back in January of this year and am absolutely in love with it. This is the first car out of school I purchased for myself and I do not think I could have made a better purchase. I'm fortunate enough to have a connect at the dealership I got it from and ended up getting it at cost! I will be updating this tread as the build progresses. The ultimate plan is a hellcat swap, atlas transfer, King coilovers and everything else needed to make that happen. The parts list so far is as follows:
• Rock Krawler 3.5” Lift
o Bilstein 5100 Shocks
• Grade 8 Upper Control Arm (Front & Rear), Lower Control Arm (Front and Rear), and Track Bar Mounting Hardware
• Rockstar V2 Rims
• Cooper 35” tires
• Synergy Chromoly Tie Rod
• Synergy High Steer Drag Link
• Synergy Front & Rear Track Bar
• Synergy Manufacturing High Mount Steering Stabilizer Bracket
• FOX ATS Steering Stabilizer
• Ripp V2 Supercharger kit
o High Altitude Pulley
• Dual Aeroforce Interceptor gauges
• A-Pillar Dual Gauge Mount
• Factor 55 Flat Link
• Factor 55 Winch Lock
• Poison Spyder Front Crusher Flares – Standard-Width (Steel)
o Rhino Lined
• Poison Spyder Rear Crusher Flares – Standard-Width (Steel)
o Rhino Lined
• Maximus-3 Spare Tire Carrier
o Hi-Lift Mount
o Axe Mount
o Full Size Spare
• Maximus 3 Zeon Winch Adapter
• Maximus 3 Zeon Filler Trim Plates
• Drake Offroad Shift Knob
• Drake Offroad Transfer Case Knob
• RCV Front Axle Shafts
• 4.88 Gearing
• Poison Spyder Differential Covers
• Poison Spyder JK 4-Door Rocker Knockers
o Frame Mounted
• Dynomax Evolution Competition Exhaust
• sPod SE System With Touchscreen
• Rugged Ridge 50’ Light Bar Mounts
• Oslamp 50’ Curved LED Light Bar
• Rough Country 20’ LED Light Bar Hood Mounting Bracket
• Auxbeam 22’ LED Light Bar
• 4x Oslamp Cube Spot Lights
• Eternalpower Dual Work Light Double Pillar Mount Bracket A-Pillar Mounting Brackets
• 2x Spot Lights (Rear)
• Eternal Power Spot Light Mounts
• Rugged Ridge CB Mount
• Uniden Bearcar 980SSB
• Pyle PA Speaker
• Firestik CB Radio Antenna
• Rugged Ridge Quick Release Mirrors
• McGard Door Locks
• TruckLite LED Headlights
• Skinny Series Front Fender Liners
• Power Stop Front & Rear Ceramic Pads W/ Drilled/Slotted Rotors
Now time for some pictures!
• Rockstar V2 Rims
• Cooper 35” tires
o Rhino Lined
o Rhino Lined
o Hi-Lift Mount
o Axe Mount
o Full Size Spare
• 4.88 Gearing
o Frame Mounted
• Pyle PA Speaker
• McGard Door Locks
