cozdude
Guy with a Red 2-Door
For a long time now there really hasn’t been a fix for the factory locker lights. Yes Z automotive made a bypass harness but it’s just a bandaid. Well it looks like mopar has stock of the locker position sensors again! They come in a pack of 5. They all have different part numbers on them so you would need to compare them to the one your removing from you locker. Part number for the new position sensors is below.
I replaced one today for a customer we previously did a regear on. He had a Z automotive bypass installed. The new sensor works as intended and I had the bypass removed. The box of 5 is only about $200. (Our shops cost was $150 so the $200 is a rough guess). Was super easy to replace as well. Just need a 10mm to remove the diff cover and a T25 torx bit to remove the sensor off the locker.
