NevadaZielmeister
Hey everyone.
So I have had the EVO MFG Tire carrier mounted on the EVO MFG Rear Corner Rockskins for about 8 months now. Unfortunately, the tire carrier still rattles. I have tried the offset on the pin side in which the tire carrier is essentially twisted to provide force against the opposing joints. I also have tried different amounts of sag on the bolt side, low sag, middle sag, and high sag. There is limited if any movement from back and forth, but there is still up and down rattle. I noticed there is a bit of space between the mount and the Johnny joints. My only thought is to slide some kind of material between the Johnny Joint and the mount plate. Trust me, I have adjusted them and adjusted them. Making one adjustment, driving it, making another adjustment, driving it. Very frustrating.
What am I doing wrong? Has anyone come up with anything different? Maybe my mounts are bent? Do you guys have that much space between the top of the Johnny Joint and the inside of the mount plate?
Any suggestions would be appreciated.
Here are some photos:
Bottom Mount with pin in:
Top Mount with pin in:
Top Mount with pin out:
Top mount showing the space between the joint and the mount plate:
Bottom mount showing the space between the joint and the mount plate:
