Evo lever question
I'm going through and retourqueing all the bolts underneath the jeep and I just wanted to double check what the upper and lower rear control arms are supposed to be torqued to on the evo lever setup. Also the shocks as well, thanks.
I think it will all be dependent on the type of hardware and grade. There are plenty of charts online. Disclaimer: I don't have that setup and am only assuming that is what would determine the torque specs
I asked the same question when my lever was installed. Check the grade 8 torque specs online.
Well the project jk torque guide says 125 ft lbs for the rear upper and lower control arms... I can't imagine the evo lever would be different but I just wanted to make sure
