Markymark420
Prior to install of these EVO Adventure Series Front Lower Control Arms that I have received as part of the Enforcer kit, I have a few questions:
1. I may be seeting them up wrong, but is the collar of the adjustment sleeve meant to be flush with the contol arm (or loosened till snug against the Johnny joint) to start?
2. The instructions call out a 22 7/8" nominal length. From those who run this kit, does this put you in the ballpark? Or, would you suggest another starting point?
3. What spanner (Brand/Part#) is used to adjust the sleeve on the vehicle?
4. The LCAs were supplied w/o the pinch bolts. None of the hardware supplied w/ the lift will work. Could I get the diameter and grip of the bolts that are utilized?
