Evo D ring w/ tire carrier
JKU EXTREME
I am going to get the Evo mfg D-ring mounts for my JKU. So the 2nd to next thing on my mod list will be a tire carrier. I like the Evo tire carrier but I don't like how I have to buy all of the skins and lights (I may get it anyway) but I also like the Genright tire carrier (in black).
So I am requesting pictures of anyone who has the Evo d rings with whatever tire carrier you have.
Thank you so much
-John
OverlanderJK
Resident Smartass
I wouldn't get the EVO carrier unless you have 37's or bigger. You can use the stock carrier for everything else.
ChaosNein
Hey, If the man wants to purchase a built-proof, made in the U.S.A. tire carrier like the EVO MFG Tire Carrier, then I say "Let Him...:cheesy:" :thumb:
The Corner Skins help distribute the weight of the carrier/tire as well as protect you quarter panels from rock damage.
OverlanderJK
Resident Smartass
I agree but I think it's a little overkill for 33's. Lol
bl17z90
Hinrich is running the exact setup you asked for, you can look at his build thread or maybe he will chime in here.
Thank you so much
-John
I have the evo d-rings with the evo tire carrier did you want photos of that combo too or just others?
redpatchjeff
if you don't want to run the EVO stuff...there are a lot of people that get the OR-FAB carrier and the EVO d-rings.
not knocking EVO by any means - just giving another alternative! :thumb:
JKU EXTREME
[\QUOTE crippledpetey]I have the evo d-rings with the evo tire carrier did you want photos of that combo too or just others?[/QUOTE]
Pictures would be helpful
JK1
EVO D-rings with a 35 with a Rugged Ridge carrier i think :idontknow:
EVO D-rings with 37's and tera flex tire carrier and hinge like this look better :yup:
good luck
:beer:
hinrichs
Genright for now
StrizzyChris
I say upgrade to EVO skins and carrier! I'll save the GenRight from the dumpster and give you a couple hundred for it :yup:
hinrichs
Why only for now? You having any issues with the GR carrier?
No issues other than the brackets slightly off and makes it a little harder to open....all my fault
Its on my list down the road, i may keep the genright and still do the skins but weld on tabs for the genright, but at the same time why not just do the evo carrier. When i originally ordered the genright I never planned to be on 37s and headlocks. It will hold up to a 42 tho so no complaints.
EVO D-rings with EVO carrier. Let me know if ya need any others.
why bolts on the carrier and not pins?
Stopped all rattles. I grabbed a bolt the exact diameter of the Johnny Joint and drilled a hole for the quick release pin and it doesn't move. Also it's funny to watch people look at it and try to figure out how it opens :cheesy:
JKU EXTREME
I wondering, since you cut the rear bumper hole[?(where the d-ring bracket was installed)] can you run a rear bumper with it cut or would you have to weld it back?
