Evo 3" Plush Coils
Let's say I start considering the 4" coils, which I am, what else will I need? I'm Currently running a 2.5" kit
Brake line extensions
Adj Track bar Front and Rear
Shocks
Draglink flip kit?
I already have all 8 Adj Control arms from Metal Cloak
anything else?
Shocks
Draglink flip kit?
anything else?
You don't need track bars if you do front flip and rear track bar bracket. Rear brake line extension brackets. Longer front brake lines. Longer sway bar links.
Shocks
Draglink flip kit?
anything else?
Driveshafts :yup:
Wouldn't the front track bar be too short, right now at 2.5" my axle is shifted a bit, I figure at 4 I would need to correct that with a front bracket at least
I'm curious how they fixed the sagging issue - I pulled the 4" off and they were shorter than my 3.5" I originally replaced.
Jeep's gotten heavier and I've gotten lazy about taking stuff out that I pack for each road trip. the weight has made the stiffer 3.5" coils ride better.
I will say the 4" with 37's was a good fit and so long as the Jeep was fairly light, they rode great.
as you can see, the top coil is almost touching the lower coil, wasn't that close when new - I didn't take a side by side comparison but overall it was about a full 1" shorter than the 3.5"
