Esp bas
Brankz
I was driving and this light's pop on and my jeep felt horrible was shaking and I felt like if the brake where on grinding!
What is this
If the brakes came on while you were going straight the Jeep probably thought you were in a High Speed turn, I would guess it's your steering sensor. I'm sure someone with more knowledge will chime in. (sorry for only providing a guess)
check your alignment brankz. it happened to me where my brakes/traction control kicked in because it thought i was in a slide. also if your alignment is in spec then maybe one of your speed sensors is now bad, once again like mine was so once replaced im all good.
Yup the same thing happen to me, can I use a code reader to see wish speed sensor is or what sensor is?
im sure if you stop by the dealer or a shop they will read it for free and tell you what one it is. or you can replace both just because. they are only $20 a side. like i said tho check your alignment first with eddies write up or bring it by a shop to do it.
Did your abs wire rub against your tire? If it runs through that could be your issue.
I don't know, how can I tell if I did?
Yea I'm going after work, I can get the sensor for 10 bucks ;)
Fix! I ripp one of the speed sensor cable in the driver side
At lest that what my body told me lol for 10 bucks I can't complain
