Electronic question
RedRum
Ok so it might just be a coincidence but after I installed my light bar the other night my usb plug in the console picks up my iPhone and plays music but doesn't charge it ... Has anyone else had this issue ?? It's not a big deal but it is frustrating
Thank you
Did you wire to the battery, fuse box or a live wire? And have you disconnected the light bar to see if the problem goes away?
Thank you
where did you tap into for the light bar power source? could be you've exceeded the draw limit if you tapped into the same source as the USB outlet.
Also pull and check the fuse.
I'd try what MR.Ty suggested and disconnect the light bar but it may just be the USB port no longer putting out enough amps.
You've been able to charge your iPhone off it before?
